19 years agoPerformance Counter offset
Hi, i have a question about the PERFORMANCE COUNTER component. I have the following code to measure the overhead from starting/stoping the counter: PERF_BEGIN (PERFORMANCE_COUNTER_BASE, 1);...
16 years agoI have a long program function in between the beigin and end. I also tried a smaller function which give 821 clks on the performance counter and it is always the same result. however when I put a bigger function, the result is different. I even have no data cache in SPOC CPU. where could be the errors?
