20 years agoPCI in uClinux
Does suported PCI in uClinux for NIOS II with Altera PCI Compiler 4.0 pci_mt_32 megafuntion ? Anywho uses this options ? I can't compile kernel with PCI support... http://forum.nio...
20 years agoHi,
i have now tested a little bit. To Hippo: DMA works. The PCI accesses the SDRAM via Master-Access. The maximum speed i reached with a Nios/f @100MHz, and CAS2/SDRAM@100MHz is: 47Mbit/s for TCP and 49Mbit/s for UDP. I think the Nios is not able to give more.... These are values under uClinux. Therefore the are not too bad, i think. But the best thing is, that PCI works. So really everything can be combined with uClinux (Wlan, MiniPCI, SCSI and so on...) To Bigboss25: I will write a NiosWiki Article soon about that. Solong Marco --- Quote Start --- originally posted by bigboss25+sep 29 2006, 02:15 am--><div class='quotetop'>quote (bigboss25 @ sep 29 2006, 02:15 am)</div>--- quote start ---
<!--quotebegin-mabcom@Sep 29 2006, 01:45 AM hi hippo,
how fast is the pci implementation?
does it works with dma? i think it's a little bit slowly when i test the pci performance with giga-ethernet.
i think the linux tcp-ip-stack doesn't use the pci-memory access.
can we solve it quickly?
thanx
marco
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18494)
--- quote end ---
--- Quote End --- Hi MadCom, would it be possible for you to create on "how-to" on Nios Wiki, explaining what you did (hardware, Ip cores used... and of course uClinux driver). I think it would help a lot of people. Thanx. Regards. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18495)</div> [/b] --- Quote End ---
