Pausing target processor: not responding.
when i try to run as NIOS II hardware, i am getting this error,
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused how can i correct it, Its running in the simulator though (NIOS instruction set simulator)17 Replies
hello,
i am currently working on DE2 70 altera kit for my final year project and want to send messages using ethernet port. i am working using SOPC builder. Firstly i want to run a small program(eg. LEDs). i have created a NIOS II system using SOPC builder, then i have used altera monitor program to compile a c program. system got downloaded on to the board but when i m trying to load it i am getting the following error. Usingcable "USB-Blaster [USB-0]", device1,instance 0x00 Pausingtargetprocessor: not responding. Resetting and trying again: FAILED Leavingtargetprocessorpaused please kindly help me to sort this error. - Altera_Forum
Did you chech the clock and reset signals, as already suggested in the thread?
i have assigned the clock and reset to iCLK_50 and iKEY(0) in the pin assignment vhdl file. but still it doest work. arent they correct?
Can you check the polarity of your reset signal? The reset input on an SOPC/QSYS design is active low, so it needs to be '1' for the CPU to work. I don't know the polarity of the KEY signals on the DE2 board.
I had some problems with the board,
now got response from the board - Altera_Forum
I had a similar problem that was solved by making sure the NIOS reset output (jtag_debug_module_reset) is connected to the reset inputs of the other components, including the NIOS itself (reset_n). The loading process was unable to pause the processor until this change was made.
I too got similar error and resolved it by making sure that my Clock and Reset pins at the top level were correctly assigned (Pin Planner/ Assignment Editor). Once fixed, this resolved the problem.
So it appears, for such messages, one must look closely at the top level (including Nios / Connected components) Clock and Reset connections.
