20 years agoPassing command line arguments to NIOS using IDE
Hi folks, I'm wondering if there is a way to pass command line arguments to the main progam running on a NIOS II through the IDE. I have been browsing the documention but found no informati...
20 years agoI do not think you can do that using the Altera HAL. If you use ucLinux then probably you can use Uboot...
Paolo
