tarun_k
6 years agoParallel NOR Flash with Stratix 10
We have planned to use parallel flash with Stratix 10 FPGA as external memory for some customer requirement.
Is there some IP available for this application to be connected with NIOS Process...
- 6 years ago
Thanks for the support.
The issue is resolved. We have a parallel NOR Flash and unfortunately we cannot use the suggested IP since that supports serial flash. However, I found Generic Tristate controller that can be modified for Parallel Flash as required for our work.
Using this controller and interfacing withTristate Conduit Pin Sharer and Tristate Conduit Bridge, we can access the Flash.
Thanks!
BoonBengT_Altera
Moderator
6 years agoGood to know that it is working, we would be closing the thread. If you have further queries, Please post a response in the next 15 days
After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Warm Regards
