Parallel NOR Flash with Stratix 10
- 6 years ago
Thanks for the support.
The issue is resolved. We have a parallel NOR Flash and unfortunately we cannot use the suggested IP since that supports serial flash. However, I found Generic Tristate controller that can be modified for Parallel Flash as required for our work.
Using this controller and interfacing withTristate Conduit Pin Sharer and Tristate Conduit Bridge, we can access the Flash.
Thanks!
Hi @tarun_k,
Good day and hope you are doing well, by any chances did you managed to look into the reference IP link?
Is there any further question or any clarification that we can help on?
Warm Regards.
Thanks!
