Other workflow for generating Preloader since Quartus-Prime Version 19.1 with "SoC EDS 19.1 Command Shell„
Before Quartus-Prime Version 19.1 workflow in "SoC EDS 18.1 Command Shell„ was:
Generate the "Preloader" using the BSP Editor
Change to Quartus Project folder:
bsp-editor.exe &
File, New ..\hps_isw_handoff\soc_system_hps_0
Generate --> ..\software\spl_bsp is generated !!
Build the "Preloader„:
Change to folder ..\software\spl_bsp
>make
--> preloader-mkpimage.bin is generated !!
SoC EDS 19.1 Command Shell„ :
bsp-editor.exe &
>make
I get the message:
"Please visit https://rocketboards.org/foswiki/Documentation/BuildingBootloader for instructions on how to build the bootloader."
But on this page I couldn't find any instuction to generate Preloader "preloader-mkpimage.bin".
Can anyone help???
Thanks for any answer.
Gerhard
FPGA-Eval-Board : DE10-Standard, Cyclone V FPGA
- GHelb
The answer may be in this post: <https://forums.intel.com/s/question/0D50P00004bZ2TkSAK/>
In part:
MeiYanL_Intel (Intel)
Could you try to install Nios II SBT v18.1 as workaround?
- GQUIR2
It is important for me to know whether Intel is skipping the generation of the preloader in all future versions of the "EDS Command Shell" and what the replacement workflow is like.
Because I have HPS, I have now put the topic under the heading "Intel® SoC FPGA Embedded Development Suite".
- FawazJ_Altera
Hello.
This is the new flow of generating the bootloader for SoC FPGA devices starting from Quartus Prime 19.1.
This flow will generate the preloader and uboot together. You should be able to see the generated folder under the u-boot-socfpga folder, u-boot with spl
