16 years agoOpencores I2C adapted to Avalon for NIOS-II 9.0
Dear all, I found a link in NiosWiki to download the opencores I2C controller adapted to Avalon (nioswiki.com >> Peripherals >> Opencores_I2c). But this is available only for the NIOS-II 9.1. ...
16 years agohi,
I have the same problem using open core vhd i have a problem on irq signal :error: i2c_master_0.interrupt_sender: associatedaddressablepoint out of range
error: i2c_master_0.interrupt_sender: interrupt not associated with addressable connection point.
i don't find the problem.
i add the files i2c_master_bit_ctrl.vhd,i2c_master_byte_ctrl.vhd, i2c_master_top.vhd,
i modifie the signals types.
the error appear
thanks for your help
