16 years agoOpencores I2C adapted to Avalon for NIOS-II 9.0
Dear all, I found a link in NiosWiki to download the opencores I2C controller adapted to Avalon (nioswiki.com >> Peripherals >> Opencores_I2c). But this is available only for the NIOS-II 9.1. ...
16 years agoHello,
I use the version 9.1 of quartus and the opencore I2C master (vhdl) but I have the follows error and warning : Error: i2c_master_0.interrupt_sender: associatedAddressablePoint out of range Error: i2c_master_0.interrupt_sender: Interrupt not associated with addressable connection point. Error: i2c_master_0.interrupt_receiver: associatedAddressablePoint out of range Error: i2c_master_0.interrupt_receiver: Interrupt not associated with addressable connection point. Warning: i2c_master_0.clock_sink: Signal reset appears 2 times (only once is allowed) Warning: i2c_master_0.interrupt_receiver: Interface has no signals Warning: cpu_0.data_master/i2c_master_0.avalon_slave_0: i2c_master_0.avalon_slave_0 does not have byteenables. Narrow (less than 32-bit) writes from cpu_0.data_master will result in spurious writes to i2c_master_0.avalon_slave_0
