16 years agoOpenCore MAC + ethoc driver + PHY
Hi all.
I noticed some people have troubles with ethoc driver for Opencore MAC getting errors like "no PHY found" and/or "failed to register MDIO bus". I had this problem and I have tracked it down. It happened that our hardware guys wired all the PHY's address lines to ground so PHY address become 0x0. And this is the root of problem since the ethoc driver rejects zero addresses. This file: drivers/net/ethoc.c in the function ethoc_mdio_probe(), check out this block of original code: if (phy) {if (priv->phy_id != -1) {
/* attach to specified phy */
if (priv->phy_id == phy->addr)
break;
} else {
/* autoselect phy if none was specified */
if (phy->addr != 0)
break;
Note the close `if (phy->addr != 0)' which prevents PHY with zero address to be attached. I have rearranged this code in the following way: if( phy ) {
/* autoselect this phy if none was specified */
if( priv->phy_id < 0 )
break;
/* attach to the specified phy if found a matching one */
if( priv->phy_id == phy->addr )
break;
Now it works perfectly, either generic or my own PHY driver gets correctly attached. But I don't think it's a proper solution. The bug is not in the driver itself but rather a hardware designer's mistake. Rejecting zero addresses is technically correct, since the 0x0 is reserved for broadcast, i.e. any PHY connected to a given MDIO should respond regardless of its actual address. So, IMHO the problem should be fixed at kernel configuration level, just we need to add a menu option to enter expected PHY address and then propagate the user's choice to `.phy_id' instead of assigning -1 unconditionally. In the file arch/nios2/kernel/config.c skip down to the structure: static struct ethoc_platform_data ethoc_pdata = { .hwaddr = { 0, }, .phy_id = -1, }; I guess it should be something like this: static struct ethoc_platform_data ethoc_pdata = { .hwaddr = { 0, }, # if defined(CONFIG_ETHOC_PHY_EXPECTED_ID) .phy_id = (s8)(CONFIG_ETHOC_PHY_EXPECTED_ID), # else .phy_id = -1, # endif }; Just I don't know how to do it :confused: Is there someone skillful with all this Kconfig/Makefile stuff? :)
