15 years agoOnly a BSP-File in NiosII-Eclipse
Hello! Im just starting to work on FPGA Programming and I am stuck, writing the software with NiosII 10.1-Eclipse. I'musing a Altera Cyclone III Evaluation board and I already built up a sma...
15 years ago --- Quote Start --- Found the solution...thank you windows 7 for stealing my time! Just need to start Nios with admin privileges. --- Quote End --- You should thank Altera instead. The Altera installer does not set the correct permissions on all of the required executables. You could theoretically change the permissions yourself, but it is easier top just run as administrator. On a positive note, I have not yet run into this same problem with 10.1.
