15 years agoOnChip memory access with external logic
Hi, I'm trying to access on-chip memory (data and instruction) from external logic. I've generated system with two dual ports on-chip memories one for data and one for instruction, and connecte...
15 years agoThinks ...
This ought to be easy, but the SOPC builder's memory options probably only expose and avalon slave memory interface - whereas you need the raw signals for the 2nd port. There is also nothing defined to let you build your own 'tightly coupled memory' block (I've not looked - but I remember someone else saying it).
