16 years ago
Not able to receive all/complete packet from UDP server
Dear Friends,
I am trying to read data from UDP server....i am sending 7 packet of size 1448 bytes. from server and at receiver end i am collecting them in a array namelly "ImgBuff[0][1448]"
and at second read i am again write my income bit stream in same memory location but before that i print the privious received data.....but it won't print my second (and second onward ) received data. even i am able to receive this first packet after enabling "zero_copy" enable through bsp_editar
My Client Code is as below.................# include <stdio.h> # include <string.h> # include <ctype.h>
/* RS232 Related Files....*/ # include "alt_types.h" # include "altera_avalon_pio_regs.h" # include "sys/alt_irq.h" # include "system.h" # include <unistd.h>
/* MicroC/OS-II definitions */ # include "includes.h"
/* Simple Socket Server definitions */ # include "simple_udp_server.h"
/* Nichestack definitions */ # include "ipport.h" # include "tcpport.h"
# define CLI_PORT 6089 # define SERVER_PORT 6090 # define SERV_HOST_ADDR "192.168.5.2"
# define MaxPkt 0xff # define PktSize 1448
//unsigned char DataPacket[0][PktSize];
unsigned char ImgBuff[0][PktSize];
struct sockaddr_in Cliaddress, Servaddress;
int sockid;
char msg[32];
size_t len;
int LocalPktCount;
int retcode = 0;
void ConnectServer()
printf("Client: creating socket\n");
if ( (sockid = socket(AF_INET, SOCK_DGRAM, 0)) < 0)
{ printf("Client: socket failed: %d\n",errno); exit(0); }
printf("Client: binding my local socket\n");
bzero((char *) &Cliaddress, sizeof(Cliaddress));
Cliaddress.sin_family = AF_INET;
Cliaddress.sin_addr.s_addr = htonl(INADDR_ANY);
Cliaddress.sin_port = htons(CLI_PORT);
if ( (bind(sockid, (struct sockaddr *) &Cliaddress,sizeof(Cliaddress)) < 0) )
{ printf("Client: bind fail: %d\n",errno); exit(0); }
printf("Client: creating addr structure for server\n");
bzero((char *) &Servaddress, sizeof(Servaddress));
Servaddress.sin_family = AF_INET;
Servaddress.sin_addr.s_addr = inet_addr(SERV_HOST_ADDR);
Servaddress.sin_port = htons(SERVER_PORT);
printf("\nConnection Establish...\n");
void RecvFromServer(void)
int PktCount1[1];
int Count = 0;
int SecondCount = 0;
LocalPktCount = 0;
fflush(stdin); //Clean the input and output buffer
len = sizeof(Servaddress);
//receive total no. of pkt to be recived from remote client, and store it in "PktCount1" variable
retcode = recvfrom(sockid,PktCount1,sizeof(PktCount1),0,(struct sockaddr *)&Servaddress,&len);
if (retcode >0)
printf("\nClient: No. of Packet to be received is: %.d\n\n",PktCount1[0]);
do
LocalPktCount++;
alt_dcache_flush();
fflush(stdin);
retcode = recvfrom(sockid,ImgBuff[SecondCount],sizeof(ImgBuff[SecondCount]),0,(struct sockaddr *) &Servaddress, &len);
if(retcode <= 0)
printf("recv call failed");
break;
else {
//SecondCount++;
printf("\n Packet No. received %d\n", LocalPktCount);
if(ImgBuff[SecondCount][0] == MaxPkt && ImgBuff[SecondCount][1] == MaxPkt)
if(LocalPktCount != PktCount1[0]+1)
printf("\n Last Packet Received...!!\n");
//SecondCount++;
continue;
break;
Count = 0;
do
// DataPacket[SecondCount][Count] = ImgBuff[SecondCount][Count];
printf("%c",ImgBuff[SecondCount][Count]);
Count++;
}while(Count != PktSize);
//Count = 2; // Initilize data address.....
Count = 0;
do
//IOWR_8DIRECT(SDRAM_BASE+LocalPktCOunt+Count,0,DataPacket[1][Count]);
Count++;
}while(LocalPktCount != PktCount1[0]+1);//compair total no. of pkt+1 recived with count value which increment after each received pkt.
printf("\nLocalPktCount = %d",LocalPktCount-1);
printf("\nFile received Completed..!!\n\n");
void SSSSimpleUDPServerTask()
ConnectServer();
printf("\nClient: Write message and sending\n");
sprintf(msg, "Hello Server This is UDP Client");
retcode = sendto(sockid,msg,32,0,(struct sockaddr *) &Servaddress,sizeof(Servaddress));
if (retcode <= -1)
printf("client: sendto failed: %d\n",errno);
exit(0);
printf("Server: starting blocking message read\n");
retcode = recvfrom(sockid,msg,32,0,(struct sockaddr *) &Servaddress, &len);
printf("Client: retrun code from read is %d\n",retcode);
if (retcode >0) printf("\nClient: Received message is: %.32s\n\n",msg);
RecvFromServer();
/* close socket */
printf("\n..........Close the UDP Connection..........!!\n");
close(sockid);
please see the attached printscreen of received file along with first packet of received data.
I am not able to increase the size of buffer as i increase the size it will start displaying garbage data see the second attachment "error5" file
kaushal
1 Reply
