10 years agoNot able to interface SDRAM with nios Processor
I have made a system with Nios processor, JTAG-UART, SDRAM(8MB), Clock Signal IP core, on chip memory. I am not able to implement the hello World Program. The nios console doesnt show anything except...
10 years agoWhat dev board are you using? It should have come with an example that uses SDRAM. Use that as your starting point.
If that doesn't work, load a pre-built .sof file that uses SDRAM to verify that your hardware is working.
