15 years agonon-cacheable instruction memory
Hi at all, I'm new in this forum. I create a Nios II system containing a Nios II/f core, with 2k data cache and 2k instruction cache, and 128k of on chip-memory. I want to run on this system an ...
15 years agoThank you for fast reply. I'm a master student and I have to realize a project on which I must to load a part of assembly program in cacheable instruction memory and the other on non-cacheable instruction memory.
From your reply I understand that all instructions load into tightly coupled memory block are not loaded into instruction cache and the instructions into on-chip memory are loaded in cache, is correct?:confused: If it is correct, how can I load a part of the assembly program into on-chip memory and the other part on tightly coupled memory block?:confused: Thank you for your helpfullness.:) Daniele.
