17 years agoNo support for CFI algorithm 1793 on 16 bit flash
hi, When i program the sst39vf160 nor flash in NiosIDE , a problem happend:No CFI Table found at address .... i search the help doc and serch internet ,i find that the override file is neede...
17 years agoall reported values are 8 bit the upper 8 bit are always 00
check if you flash is in 8 bit mode next check if you use 16bit mode that nios adr 0 is not connected as adr bit 0 it is always 0 in 16 bit accesses nios a1 should go to flash a0, but some manufacures like spansion label adr bit 0 as a-1 if it is a 16 bit device with 8bit mode. regards michael
