MHahn4
7 years agoNo Nios II target connection
Hi, I'm trying to get the Hello World Nios II example to run on an Cyclone 10 GX. The design build and the sof-programming run without a problem. But the Nios II Eclipse can't find the Nios as targe...
AnandRaj_S_Intel
7 years agoHi Michael,
Regarding Jtagconfig -n.
- Your image does not contain a Nios II processor with a JTAG debug module enabled or JTAG UART component.
- Load image with Nios II processor with a JTAG debug module enabled
For example, check the image
Are you using a cyclone 10 GX dev kit? IF yes please try to load the factory image.
Anand
