17 years agono mmu problem
I builde the zImage on uClinux use the web_server sopc hardware project on the NEEK board. I have selected the frame buffer driver, the jpegview application and mygui application. Use the jpegvi...
16 years ago --- Quote Start --- This issue was resolved. Please pull the updates, clean and rebuild. cd uClinux-dist make user/microwin_clean make - Hippo --- Quote End --- Hi,Hippo I'm a newbie and I get the same problem: BUG: failure at /aaa/nios2-linux/linux-2.6/mm/nommu.c:530/add_nommu_region()! Kernel panic - not syncing: BUG! But I don't know how to "pull the updates".Could you please explain it for me?Thank you.
