17 years agono mmu problem
I builde the zImage on uClinux use the web_server sopc hardware project on the NEEK board. I have selected the frame buffer driver, the jpegview application and mygui application. Use the jpegvi...
17 years agoI tried running the code listed above on a NIOSII processor. I got the following results.
set_fb Start: 34 set_fb fbcon engine: Error when reading screen info: 42. cannot open /dev/fb0 TestMyGUI InitMyGUI OK 85. set_fb Start: 34 set_fb Continue: 47 cannot open /dev/fb0 TestMyGUI TestMyGUI OK 101. I then tried running the following code on the NIOSII. I had success running this same code on a PC running Linux.# include <unistd.h># include <stdio.h># include <fcntl.h># include <linux/fb.h># include <sys/mman.h>
int main()
int fbfd = 0;
struct fb_var_screeninfo vinfo;
struct fb_fix_screeninfo finfo;
long int screensize = 0;
char *fbp = 0;
int x = 0, y = 0;
long int location = 0;
// Open the file for reading and writing
fbfd = open("/dev/fb0", O_RDWR);
if (!fbfd) {
printf("Error: cannot open framebuffer device.\n");
exit(1);
printf("The framebuffer device was opened successfully.\n");
// Get fixed screen information
if (ioctl(fbfd, FBIOGET_FSCREENINFO, &finfo)) {
printf("Error reading fixed information.\n");
exit(2);
// Get variable screen information
if (ioctl(fbfd, FBIOGET_VSCREENINFO, &vinfo)) {
printf("Error reading variable information.\n");
exit(3);
printf("%dx%d, %dbpp\n", vinfo.xres, vinfo.yres, vinfo.bits_per_pixel );
// Figure out the size of the screen in bytes
screensize = vinfo.xres * vinfo.yres * vinfo.bits_per_pixel / 8;
// Map the device to memory
fbp = (char *)mmap(0, screensize, PROT_READ | PROT_WRITE, MAP_SHARED, fbfd, 0);
if ((int)fbp == -1) {
printf("Error: failed to map framebuffer device to memory.\n");
exit(4);
printf("The framebuffer device was mapped to memory successfully.\n");
x = 100; y = 100; // Where we are going to put the pixel
// Figure out where in memory to put the pixel
for ( y = 100; y < 300; y++ )
for ( x = 100; x < 300; x++ ) {
location = (x+vinfo.xoffset) * (vinfo.bits_per_pixel/8) +
(y+vinfo.yoffset) * finfo.line_length;
if ( vinfo.bits_per_pixel == 32 ) {
*(fbp + location) = 100; // Some blue
*(fbp + location + 1) = 15+(x-100)/2; // A little green
*(fbp + location + 2) = 200-(y-100)/5; // A lot of red
*(fbp + location + 3) = 0; // No transparency
} else { //assume 16bpp
int b = 10;
int g = (x-100)/6; // A little green
int r = 31-(y-100)/16; // A lot of red
unsigned short int t = r<<11 | g << 5 | b;
*((unsigned short int*)(fbp + location)) = t;
munmap(fbp, screensize);
close(fbfd);
return 0;
I get the following result. The framebuffer device was opened successfully. 640x480, 16bpp Error: failed to map framebuffer device to memory. Does anybody have an idea why mmap doesn't seem to work?
