17 years agono mmu problem
I builde the zImage on uClinux use the web_server sopc hardware project on the NEEK board. I have selected the frame buffer driver, the jpegview application and mygui application. Use the jpegvi...
17 years ago<div class='quotetop'>QUOTE (hippo @ Aug 26 2009, 10:17 PM) <{post_snapback}> (index.php?act=findpost&pid=23617)</div>
--- Quote Start --- Please check the mmap call in your code. This is what used in microwin scr_fb.c, psd->addr = mmap(NULL, psd->size, PROT_READ|PROT_WRITE,MAP_PRIVATE|MAP_FILE,fb,0); - Hippo[/b] --- Quote End --- My code:int open_fb(void)
fb_fp = open("/dev/fb0", O_RDWR);
if(fb_fp <= 0)
printf("cannot open /dev/fb0\n");
return -1;
return fb_fp;
int set_fb(void)
//usleep(100000); // Wait 100 ms
printf("%s Start: %d \n", __FUNCTION__, __LINE__);
//usleep(10000); // Wait 10 ms
struct fb_var_screeninfo fb_var;
struct fb_fix_screeninfo fb_fix;
if(ioctl(fb_fp, FBIOGET_FSCREENINFO, &fb_fix) == -1 ||
ioctl(fb_fp, FBIOGET_VSCREENINFO, &fb_var) == -1) {
printf("%s fbcon engine: Error when reading screen info: %d.\n", __FUNCTION__, __LINE__);
return -1;
printf("%s Continue: %d \n", __FUNCTION__, __LINE__);
color_bits = (fb_var.bits_per_pixel+ 7)/ 8;
screen_width = fb_var.xres;
screen_height = fb_var.yres;
// frame_base = mmap(0, fb_var.xres * fb_var.yres* fb_var.bits_per_pixel/ 8, PROT_READ|PROT_WRITE, MAP_PRIVATE, fb_fp, 0);
frame_base = mmap(NULL, fb_var.xres * fb_var.yres* color_bits, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FILE, fb_fp, 0);
if(MAP_FAILED == frame_base)
printf("Error mmap frame buffer.\n");
return -1;
return 0;
void close_fb(void)
munmap(frame_base, screen_width* screen_height* color_bits);
close(fb_fp);
void TestMyGUI(void)
int i;
for(i=0; i<10; i++)
if(open_fb() > 0)
set_fb();
usleep(10000);
close_fb();
else break;
printf("%s InitMyGUI OK %d. \n", __FUNCTION__, __LINE__);
for(i=0; i<10; i++)
if(open_fb() > 0)
set_fb();
// SetGUIBackColor((i*8)%256, (i*10)%256, (i*12)%256);
// GUIFillRect(0, 0, screen_width-1, screen_height-1);
// GUIFillRect(10, 10, 100, 100);
*(((int *)frame_base)+ 16101) = (((i*8)%256)<<16) | (((i*10)%256) <<8) | ((i*12)%256);
usleep(10000);
close_fb();
else break;
printf("%s TestMyGUI OK %d. \n", __FUNCTION__, __LINE__);
} The first times is OK. But twice or more times error: set_fb Start: 64 set_fb Continue: 81 set_fb Start: 64 set_fb Continue: 81 TestMyGUI TestMyGUI OK 153. /> mygui set_fb Start: 64 set_fb Continue: 81 BUG: failure at /home/nios2-linux/linux-2.6/mm/nommu.c:530/add_nommu_region()! Kernel panic - not syncing: BUG!
