14 years agoNo Ethernet with nios2 mmu stdandard design
I'm currently trying to build my own custom FPGA design. I'm using the Nios2 nios2_linux_3c120_125mhz example from Altera Wiki and also the design from Altera website nios2 mmu example design. (http://www.altera.com/support/examples/nios2/exm-mmu.html) When I power on my 3c120 devboard with uClinux distribution U-boot is launched. And you can try to ping your computer. Nevertheless, Ethernet is only working with the .sof nios2_linux_3c120_125mhz from Altera wiki (quartus 8.1). When I recompile this design under quartus 11.1 a top_time_limited.sof is generated, but when downloaded on the board Ethernet doesn't work because I can't ping my computer under U-boot. (TX LED is blinking on the Ethernet port but program display "Using tse0 device, ping failed host not alive..." ). I think the problem comes from the FPGA design or quartus version. Or maybe TSE component which is an opencore plus IP. Ethernet doesn't work also for the two design from Altera website qsys and sopcbuilder version. Please help ! :cry:1 Reply
Actually, Ethernet is working with uClinux but not working with u-boot:
When the nios2_3c120_1258mhz_top.sof design is downloaded, U-boot start : U-Boot 2009.01 (Apr 25 2009 - 13:37:29) CPU : Nios-II SYSID : 0x45ff1c2a, Fri Jan 30 03:53:01 2009 BOARD : Altera 3C120 Net: board eth init Altera TSE init Marvell 88E1111S found tse0 Hit any key to stop autoboot: 0 ==> With my custom_fpga.sof, U-boot start U-Boot 2009.01 (Apr 25 2009 - 13:37:29) CPU : Nios-II SYSID Net: board eth init Altera TSE init Marvell 88E1111S found tse0 Hit any key to stop autoboot: 0 ==> Nothing after SYSID ? My SYSID in qsys is 0x0. Could it explain the fact that ping and dhcp don't work ?
