15 years agoNo Boot with compressed zImage but vmlinux
I have problems with booting uClinux (NOMMU) on a Cyclone C1C12 Development Board. The build of the kernel from nios2-linux-20090730.tar and the toolchain nios2gcc-20080203.tar seems to work. No errors, just some warnings. When I download the compressed "zImage" to my SDRAM and try to boot uClinux comes the message "Uncompressing Kernel". But after a while nothing happens. The message "booting linux" does NOT appear. But when I use the uncompressed image "vmlinux" in linux-2.6./ directory uClinux starts. Any help appreciated. Urmel3 Replies
Now the compressed image works. Don't ask me how ;)
But sometimes I still got problems while downloading the image to RAM. "Verifiy failed between ..." is the message but the address where it fails mostly differs. The The SDRAM has 16MB so I don't think the image which is compressed 1,2 MB and uncompressed 2 MB is too big for it. The link offset is set to 0x50000. Could it be a timing problem between SDRAM and the cpu? - Altera_Forum
Looks like not correctly working RAM.
-Michael - Altera_Forum
Thanks for the info.
The failure was due to the link offset. It had to be about 2/3 of the SDRAM size (found the hint somewhere in the alterawiki). The offset of 0x50000 was to small for the 16 MB RAM. So I used a higher offset like 0x00AAAAAA. Now it works fine every time i want to upload a new image. Bye Urmel
