NGord
2 years agoNiosV
Hi I am in the process of converting a MAX10 Nios2 design to a MAX10 NiosV. It boots from Flash loaded into DDR All is good with the compiling apart from I need to convert the elf file to a hex fi...
tehjingy_Altera
2 years agoHi
The nios2-elf-obj is available under the nios2 command shell.
To launch you can use the nios2-elf-objcopy.exe shown below:
Jingyang, Teh
