20 years agoNiosII Uart Interrupt Handler
Hi!! I wrote Uart Interrupt Handler For NiosII. and use it. [CODE] //----------------------------------------------------------------------------- //Description : Uart Interrupt Handler & Q Buffe...
15 years ago --- Quote Start --- Hi blugem1, I am working on nios2 project using 1 uart and 1 ethernet port and your code helps me very much. My system works exactly as I need now. Where do you get the information of primitive function such as ? Maybe I will need that the source for ethernet part of my system. I didn't use that kind of function in my previous code so that my system only worked from PC to FPGA and not in otherwise. Thank you very much.. --- Quote End --- ariefgrand, you can find ALTERA_AVALON_UART_STATUS_TRDY_MSK and IORD_ALTERA_AVALON_UART_STATUS in altera_avalon_uart_regs.h that in <altera install directory>/ip/altera/sopc_builder_ip
