aamlb
6 years agoNiosII QSPI Flash
We have a NIOSII design which use QSPI flash (as NVM, no for programming).
There are 2 IPs that could be used for this:
1. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/lite...
EricMunYew_C_Intel
6 years agoHi, Alon
Can we close this if you have no more inquiry ?
Eric
- aamlb6 years ago
Hi Eric,
We would like to use the a QSPI flash to contains the NIOSII application, and then copied it to the RAM.
The instruction as described in 'Embedded Design Handbook', version '2020.07.22', section '5.2.4.3. Nios II Processor Application Copied from QSPI Flash to RAM Using Boot Copier', use the 'Generic QUAD SPI Controller'.
As mentioned before, we use the 'Generic serial flash' controller to access the QSPI flash.
The question is, does the 'Generic serial flash' support the 'boot copier' option? and what is the required configuration?
