10 years agoNiosII continuously rebooting
Hi, My niosII is continuously rebooting at the same code position. The Nios is running on an external SDRAM (I'm using a cyclone IV EP4CE30F484). The memory test runs OK (it looks like the memo...
10 years agomore information:
There is a function that has two nested for loops that initialize a array of a struct variable. When I commented it out the code stopped crashing. When that function is there it crashes and reboots. However, if I change the exception vector offset from 0x00000020 to 0x00020020 (and with the function uncommented) it stops crashing in that function and crashes somewhere else. :confused:
