10 years agoNiosII continuously rebooting
Hi, My niosII is continuously rebooting at the same code position. The Nios is running on an external SDRAM (I'm using a cyclone IV EP4CE30F484). The memory test runs OK (it looks like the memo...
10 years agoHi,
Thanks for the response. My bootloader is on the flash. I have used this configuration for other projects and it always worked fine. And for this project it works if I add some offset to the exception vector (or run a smaller C project).
