11 years agoNiosII booting from on-chip memory
I am trying to boot a NiosII (HAL only, no other bigger OS) on a Cyclone IV directly from the on-chip memory. I have initialized the memory .hex file and included it in my project. I then recompiled ...
11 years ago --- Quote Start --- If you are using nios2-download to download software then you might have a look at the -g and -r options, and also at how the debug reset output is connected in QSYS. Otherwise if you are using nios2-configure-sof to configure the hardware then its harder to guess at the cause. Is the design constrained in timequest? --- Quote End --- I prepared the *.hex file so that it become part of the *.sof file. I assume that by you only downloading the *.sof the NiosII should start running. I got it working if I do serial passive programming, but no when only using QuartusII programmer in the JTAG mode. The NiosII reset I have it connected to Vcc all the time. Regarding timequest no. I have not tinkered with it at the moment. Any suggestions?
