16 years agoNIOSII addressing for 32 bit wide SDRAM
Hello, first time poster here. As the title suggests, I have an FPGA accessing a 32 bit wide DDR2 device (actually 2x 16 bit devices with appropriately shared signals). Using SOPC builde...
16 years agoThanks for the reply, BadOmen.
As mentioned: >>Using SOPC builder to generate a simple system with mainly NIOSII/f and one >>HPCII DDR2 controller. Would you recommend trying to close timing on this project before anything else though? If so, if I am going to run this thing at 200MHz with a -6 ArriaIIGX then perhaps I need to alter the HDL indirectly through SOPC changes(either parametric for the given current components or architecturally by for example adding a pipelining bridge) as "Report Timing" in Timequest shows a number of violations(neg slack) even for clk to clk transfers(ie. launch and latch clock are the same). Hints here? SignalTap of use here also versus setting up sims? Your thoughts? Regards.
