10 years agoNios/e prints only in eclipse debug mode on jtag-uart, not in eclipse 'normal' mode
Hi, I'm using the C5 Soc Kit from terasic. http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=205&no=816 I have created a Nios system with qsys in q13.1 (on wi...
10 years ago --- Quote Start --- Do you have a push button or FPGA reset that you can use at top level? I am concern with the jtag_debug_module_reset_output driving the clock source IP. Can you instead export the clk_in_reset? Probably you can use the System >> Create Global Reset Network for correctly hooking up the jtag reset output. --- Quote End --- @ mikedsouze: I've followed your suggestions. - I've exported the clk_in_reset - I've created a global reset network. - See attachment qsys_reset_export_system_generated_reset_netw.png - I've updated my verilog code
assign nios_reset = KEY;
nios_4b_qsys NIOS2
.clk_clk(clk), //, // clk.clk
.reset_reset_n(nios_reset) // reset.reset_n
And now it works in normal mode!!! Not after the first download when I press the run button in eclipse, but when I press the key that is connected to the nios_reset signal in my code. Thanks a lot mikedsouze @fredbk: Thanks for the suggestion for using a PIO with a LED. The PIO would be my next IP to add to my nios system. Using it as a watchdog is very helpfull. Rgds, Kimberley
