16 years ago
nios2 with nommu of the test-nios2 branch booting trapped with the ghost
Oh on fire, who can help me, man?
this is the boot info below,in my custom Cyclone II board for nios2, I thought I have meet a ghost.
[NiosII EDS]$ nios2-download -g zImage
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 570KB in 13.1s (43.5KB/s)
Verified OK
Starting processor at address 0x02500000
/cygdrive/d/..../image
[NiosII EDS]$ nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios
nios2-terminal: II systems. You may experience intermittent JTAG communication
nios2-terminal: failures with this cable. Please use a USB Blaster revision B
nios2-terminal: cable or another supported cable. Please refer to the file
nios2-terminal: errata.txt included in the Nios II development kit documents
nios2-terminal: directory for more information.
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Uncompressing Linux... Ok, booting the kernel.
I did not know whether I got the success to boot the kernel. Because I have cut off the network module.
How do I to debug the kernel when it start , any advice? any tools ?any recommended? are OK.Many thanks for the cool man.
    I suspected that I compile the kernel on the vmware 7.1.1 with Ubuntu 10.04 LTS. Also, I tried the nios2 tar 20100621,20090929,20080619 using the default setting. All reports are like this problem.
    Does anyone compile it in the vmware?
    --- Quote Start ---
    --- Quote End ---
    Have you find any solution to solve this problems? Can sharing the solution and thankss very much!!
