21 years agoNios2 Performance
I just ran some benchmarks for an ARM922 and a NIOS2/f. Both were run with the same code and ran at 90MHz. I did benchmarks for interger multiply, integer divide, floating point multiply, and float...
21 years agoI didn't use any cycle count comparisons, but I used a standard digital output connected to a logic analyzer. I would set the output at the beginning of the function and then reset it. The function runs in a massive loop, so the output set/reset timing is negligable. The only difference between the code is how I do the set/reset of the digital line. Here is the fp code that was run on each processor:
In the main funct: pio_data |= set_mask[2]; IOWR_ALTERA_AVALON_PIO_DATA (USER_PIO_BASE, pio_data); fsum = TestFloatMult(); pio_data &= reset_mask[2]; IOWR_ALTERA_AVALON_PIO_DATA (USER_PIO_BASE, pio_data); Fmult benchmark funct (simple mult/accum): float TestFloatMult(void) { register float *ptr1, *ptr2, sum; int i; sum = 0; ptr1 = &gFloatArray1[0]; // gFloatArray1 is a randomly generated float array ptr2 = &gFloatArray2[0]; // gFloatArray2 is a randomly generated float array for(i=0; i < ARRAY_SIZE; i++) // ARRAY_SIZE = 1000 { sum += *ptr1++ * *ptr2++; } return sum; } What I found is that the ARM executed it in 940uS and the NIOS in 7.0mS. I went to great lengths (mix mode) to make sure that the ARM did not optimize the crap out of the loop. Everything looked normal. Rick
