15 years agonios2-linux-20100621 toolchain-build problems !!!
Hi all, I downloaded the latest version nios2-linux-20100621, and followed the guides from Nios wiki carefully to build the tool chain for uClinux. But I get stuck at building uClibc step, er...
15 years ago --- Quote Start --- After change to nios-test branch in linux-2.6, the problems above are solved. But another issues appear: This one seems to be concerned with GCC compiler???
/tmp/ccwwD57R.s: Assembler messages:
/tmp/ccwwD57R.s:1148: Internal error!
Assertion failure in md_number_to_chars at /home/kevin/nios2-linux/toolchain-build/../binutils/gas/config/tc-nios2.c line 1353.
Please report this bug.
make: *** Error 1
make: Leaving directory `/home/kevin/nios2-linux/toolchain-build/build/gcc-build/nios2-linux-uclibc/mno-hw-mul/libstdc++-v3/libsupc++'
make: *** Error 1
make: Leaving directory `/home/kevin/nios2-linux/toolchain-build/build/gcc-build/nios2-linux-uclibc/mno-hw-mul/libstdc++-v3'
make: *** Error 2
make: *** Error 1
make: Leaving directory `/home/kevin/nios2-linux/toolchain-build/build/gcc-build/nios2-linux-uclibc/libstdc++-v3'
make: *** Error 2
make: *** Error 2
make: *** Error 2
make: Leaving directory `/home/kevin/nios2-linux/toolchain-build/build/gcc-build'
make: *** Error 2
--- Quote End --- Is this on the 64-bit host?
