15 years agonios2-linux-20100621 toolchain-build problems !!!
Hi all, I downloaded the latest version nios2-linux-20100621, and followed the guides from Nios wiki carefully to build the tool chain for uClinux. But I get stuck at building uClibc step, er...
15 years agoHi,
is there really a need not to use the prebuild toolchain? I also tried building the toolchain on my own but it took almost a hour and at the end there will still some problems. The traps message could be due to the compiler version of gcc. Probably you have a gcc other than 4.2.
