14 years agonios2-linux-20100621 toolchain build errors(on Ubuntu 11.10)
I'm trying to install uclinux( nios2-linux-20100621 ), my OS is Ubuntu 11.10. When build the toolchain
cd toolchain-build
git clean -f -x -d
make gcc elf2flt gdb-host
I got errors:
/bin/sh ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c -o ihex.lo /home/yang/nios2-linux/toolchain-build/../insight/bfd/ihex.c
gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c /home/yang/nios2-linux/toolchain-build/../insight/bfd/ihex.c -o ihex.o
/bin/sh ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c -o stabs.lo /home/yang/nios2-linux/toolchain-build/../insight/bfd/stabs.c
gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c /home/yang/nios2-linux/toolchain-build/../insight/bfd/stabs.c -o stabs.o
/bin/sh ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c -o stab-syms.lo /home/yang/nios2-linux/toolchain-build/../insight/bfd/stab-syms.c
gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c /home/yang/nios2-linux/toolchain-build/../insight/bfd/stab-syms.c -o stab-syms.o
/bin/sh ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c -o merge.lo /home/yang/nios2-linux/toolchain-build/../insight/bfd/merge.c
gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c /home/yang/nios2-linux/toolchain-build/../insight/bfd/merge.c -o merge.o
/bin/sh ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c -o dwarf2.lo /home/yang/nios2-linux/toolchain-build/../insight/bfd/dwarf2.c
gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c /home/yang/nios2-linux/toolchain-build/../insight/bfd/dwarf2.c -o dwarf2.o
/bin/sh ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c -o simple.lo /home/yang/nios2-linux/toolchain-build/../insight/bfd/simple.c
gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c /home/yang/nios2-linux/toolchain-build/../insight/bfd/simple.c -o simple.o
/bin/sh ./libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c -o archive64.lo /home/yang/nios2-linux/toolchain-build/../insight/bfd/archive64.c
gcc -DHAVE_CONFIG_H -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I. -I. -I/home/yang/nios2-linux/toolchain-build/../insight/bfd -I/home/yang/nios2-linux/toolchain-build/../insight/bfd/../include -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c /home/yang/nios2-linux/toolchain-build/../insight/bfd/archive64.c -o archive64.o
/home/yang/nios2-linux/toolchain-build/../insight/bfd/archive64.c: In function 'bfd_elf64_archive_slurp_armap':
/home/yang/nios2-linux/toolchain-build/../insight/bfd/archive64.c:45:12: error: variable 'arhdrpos' set but not used
cc1: all warnings being treated as errors
make: *** error 1
make:Leaving directory `/home/yang/nios2-linux/toolchain-build/build/gdb-host/bfd'
make: *** error 1
make: *** error 2
make: *** error 2
make:Leaving directory `/home/yang/nios2-linux/toolchain-build/build/gdb-host'
make: *** error 2
make: *** error 2
I'm following this altera-wiki: http://www.alterawiki.com/wiki/install_nios_ii_linux#on_debian.2fubuntu: How can I fix these errors? need help, thanks in advance, Yang1 Reply
Before these errors, I overcome the error below:
by doing what Magog said --- Quote Start --- We had the same problem. It can be solved by modifying file nios2-linux/gcc3/gcc/c-parse.y. From the line 1650, 1661, 1670 and 1675 modify $$ to $<ttype>$. For example change the line 1650 from { $$ = start_struct (RECORD_TYPE, $2); to { $<ttype>$ = start_struct (RECORD_TYPE, $2); --- Quote End --- in http://www.alteraforum.com/forum/showthread.php?t=22528gcc: c-parse.c: No such file or directory gcc: no input files make: *** Error 1 make: Leaving directory `/nios2-linux/toolchain-build/build/gcc-bootstrap-build/gcc' make: *** Error 2 make: Leaving directory `/nios2-linux/toolchain-build/build/gcc-bootstrap-build' make: *** [/nios2-linux/toolchain-build/bui
