14 years agonios2-linux-20100621 toolchain build errors(on Ubuntu 11.10)
Hi, I'm trying to install uclinux( nios2-linux-20100621 ), my OS is Ubuntu 11.10. When build the toolchain
cd toolchain-build
git clean -f -x -d
make gcc elf2flt gdb-host
I got erro...
14 years agoBefore these errors, I overcome the error below:
gcc: c-parse.c: No such file or directory
gcc: no input files
make: *** Error 1
make: Leaving directory `/nios2-linux/toolchain-build/build/gcc-bootstrap-build/gcc'
make: *** Error 2
make: Leaving directory `/nios2-linux/toolchain-build/build/gcc-bootstrap-build'
make: *** [/nios2-linux/toolchain-build/bui
by doing what Magog said --- Quote Start --- We had the same problem. It can be solved by modifying file nios2-linux/gcc3/gcc/c-parse.y. From the line 1650, 1661, 1670 and 1675 modify $$ to $<ttype>$. For example change the line 1650 from { $$ = start_struct (RECORD_TYPE, $2); to { $<ttype>$ = start_struct (RECORD_TYPE, $2); --- Quote End --- in http://www.alteraforum.com/forum/showthread.php?t=22528
