Nios2 generic_quad_spi_controller2 set dummy clycles
if you configure the Volatile Configuration Register or Non-Volatile Configuration Register for the Number of dummy clock cycles, it generates some dummy clock cycles before command execution. it may cause some data loss. so we are not recommended to configure the Volatile Configuration Register or Non-Volatile Configuration Registers.
To slow down the refresh rate please control the DCLOCK. for this follow the billow document.
Thank you,
- FRava33 years ago
Hi Hareesh,
So, this means that we cannot configure the dummy cycles of the flash using the controller2 driver, hence to configure the actual working clock frequency of the flash.
In order to use flash we need to know the clock frequency we can use to drive it, so we must know how :
-1 the dummy clock cycles setting .
-2 If the flash is set in QuadOut Fast Read or Quad I/O fast read
This is because the controller2 doesn't provide any information regarding the above .
