19 years agonios2-download -g zImage ERROR!!!!!
Hi All !
I did step by step guide by Wiki . + I build success kernel and application (hello) + but I have error when download kernel into board !!! nios2-download -g zImage ---> this is message uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 128 (order: 7, 512 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 14868k/16384k RAM, 0k/0k ROM (1189k kernel code, 169k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 1024 (order: 0, 4096 bytes) TCP bind hash table entries: 1024 (order: 0, 4096 bytes) TCP: Hash tables configured (established 1024 bind 1024) TCP reno registered io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.1 $ ttyJ0 at MMIO 0x80801080 (irq = 2) is a jtag_uart TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 17 no filesystem could mount root, tried: kernel panic - not syncing: vfs: unable to mount root fs on unknown-block(0,0) Thanks for help !11 Replies
--- Quote Start --- If you are using the MMU and you've generated a *.dts file to be linked then I'd bet that your sopc2dts has some entries that need to be tweeked. If there are unknown entries then you need to fix those first. --- Quote End --- Yes i am trying to use MMU and i've generated .dts file to be linked. But i am not sure how to fix dts file. Please help me. My dts file includes: /* * This devicetree is generated by sopc2dts on Fri Apr 19 16:30:38 EEST 2013 * Sopc2dts is written by Walter Goossens <[email protected]> * in cooperation with the nios2 community <[email protected]> */ /dts-v1/; / { model = "ALTR,onur"; compatible = "ALTR,onur"; # address-cells = < 1 >; # size-cells = < 1 >; cpus { # address-cells = < 1 >; # size-cells = < 0 >; cpu: cpu@0x0 { device_type = "cpu"; compatible = "ALTR,nios2-12.1"; reg = < 0x00000000 >; interrupt-controller; # interrupt-cells = < 1 >; clock-frequency = < 50000000 >; /* embeddedsw.CMacro.CPU_FREQ type NUMBER */ dcache-line-size = < 32 >; /* embeddedsw.CMacro.DCACHE_LINE_SIZE type NUMBER */ icache-line-size = < 32 >; /* embeddedsw.CMacro.ICACHE_LINE_SIZE type NUMBER */ dcache-size = < 2048 >; /* embeddedsw.CMacro.DCACHE_SIZE type NUMBER */ icache-size = < 4096 >; /* embeddedsw.CMacro.ICACHE_SIZE type NUMBER */ ALTR,implementation = "fast"; /* embeddedsw.CMacro.CPU_IMPLEMENTATION type STRING*/ ALTR,pid-num-bits = < 8 >; /* embeddedsw.CMacro.PROCESS_ID_NUM_BITS type NUMBER */ ALTR,tlb-num-ways = < 16 >; /* embeddedsw.CMacro.TLB_NUM_WAYS type NUMBER */ ALTR,tlb-num-entries = < 256 >; /* embeddedsw.CMacro.TLB_NUM_ENTRIES type NUMBER */ ALTR,tlb-ptr-sz = < 8 >; /* embeddedsw.CMacro.TLB_PTR_SZ type NUMBER */ ALTR,has-mul; /* embeddedsw.CMacro.HARDWARE_MULTIPLY_PRESENT type NUMBER*/ ALTR,reset-addr = < 0xc0000000 >; /* embeddedsw.CMacro.RESET_ADDR type NUMBER */ ALTR,fast-tlb-miss-addr = < 0xc8001000 >; /* embeddedsw.CMacro.FAST_TLB_MISS_EXCEPTION_ADDR type NUMBER */ ALTR,exception-addr = < 0xc0000020 >; /* embeddedsw.CMacro.EXCEPTION_ADDR type NUMBER */ }; //end cpu@0x0 (cpu) }; //end cpus memory@0 { device_type = "memory"; reg = < 0x08001000 0x00000400 0x00000000 0x08000000 >; }; //end memory@0 sopc@0 { device_type = "soc"; ranges; # address-cells = < 1 >; # size-cells = < 1 >; compatible = "ALTR,avalon", "simple-bus"; bus-frequency = < 50000000 >; jtag: serial@0x8001440 { compatible = "ALTR,juart-12.1", "ALTR,juart-1.0"; reg = < 0x08001440 0x00000008 >; interrupt-parent = < &cpu >; interrupts = < 1 >; }; //end serial@0x8001440 (jtag) timer: timer@0x8001420 { compatible = "ALTR,timer-12.1", "ALTR,timer-1.0"; reg = < 0x08001420 0x00000020 >; interrupt-parent = < &cpu >; interrupts = < 0 >; clock-frequency = < 50000000 >; }; //end timer@0x8001420 (timer) }; //end sopc@0 chosen { bootargs = "debug console=ttyJ0,115200"; }; //end chosen }; //end /
