19 years agonios2 cyclone 2 problem
Hi there I am very new to the forum and hope anyone there could help. I have designed a SOPC component that seem to work well so far since I can read and write registers from C++(nios2) howe...
19 years ago --- Quote Start --- originally posted by tantapion@Nov 6 2006, 07:56 AM hi there
i am very new to the forum and hope anyone there could help.
i have designed a sopc component that seem to work well so far since i can read and write registers from c++(nios2) however whenever i try to change the value of my register from my verilog hdl code it does not seem to work as the value written with c++ (in nios2) keeps coming back. how do i fix that can anyone help please?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19218)
--- quote end ---
--- Quote End --- Are you seeing the first access work but all other accesses fail? Chances are you are running into a cache coherency problem. Read page 131 out of 242 of this document to find out how to bypass the cache: http://www.altera.com/literature/hb/nios2/n2sw_nii5v2.pdf (http://www.altera.com/literature/hb/nios2/n2sw_nii5v2.pdf)
