10 years agonios2 + 8GB DDR3 /DDR3 SDRAM Controller with UniPHY
I'm trying to finish a simple test with a nios2/f + 1Mb on-chip memory + DDR3 controller. The DDR3 controller is connected to 8Gb DDR3 controller, which I took straight from the board manufacture...
10 years agoYou see, after some haggling to erase the other errors, the remaining are one for each NIOS: "Address width above 32 bits are not supported for Nios II".
So QSYS with NIOS is limited to 32 bit addressing internally no matter what. I tried building a subsystem but it seems QSYS does not treat subsystems any differently, it's just a visual aid. What I ended up doing is to write them out as two separate qsys blocks and then join them through a pipeline bridge through verilog/top. Let's see if it works!
