10 years agonios2 + 8GB DDR3 /DDR3 SDRAM Controller with UniPHY
I'm trying to finish a simple test with a nios2/f + 1Mb on-chip memory + DDR3 controller. The DDR3 controller is connected to 8Gb DDR3 controller, which I took straight from the board manufacture...
10 years agoHi Mike,
Thank you. I think that's exactly what is needed. However when I add all those to the *same* qsys project, it still complains about the address range. I believe qsys uses the biggest address range as a parameter so therefore I will have to break this down into two or more qsys projects. Is making the NIOS a subsystem of the main project a solution? Is there any way to accomplish this inside qsys without having to rewire everything through verilog/top?
