11 years agoNIOS with 2Gb SDRAM
Hi all, I have come across some problems using NIOS in my project. here is the background: I have a 2Gb DDR2 for the NIOS to run on. I have build the Qsys and connected all components. but when ...
11 years agoI would suggest to disconnect the cpu.data_master/altmemddr_0.s0 and connect the cpu.data_master to the direct_window_bridge_0 so that the data_master has the same "view" with the instruction master.
In your linker region the data_memory is located at 0x1400_0000 to 0x1fff_ffff. How can the instruction runs since it is still pointing to 0x1000_0000?
