Benitez__Domingo's avatar
Benitez__Domingo
11 months ago
Nios V/c issue: no valid Nios V instance
I have synthesised a Nios V/c (3.0.0)-based SoC on a DE0-Nano board, which was successfully configured using the quartus_pgm command via a Nios V-shell terminal in Quartus Prime Standard 24.1.
However, when the niosv-download command is executed after generating BSP and ELF files, the following message appears on the display:
... There are no devices with valid Nios V instance(s)
ERROR: Failed to generate OpenOCD config file. ...
However, if the same Quartus project is compiled with the Nios V/c (3.0.0) core replaced by a multicycle Nios V/m (26.0.0) core, this error does not appear, and the program runs successfully.
Could you please provide any hints on how to fix this error for the Nios V/c IP ?
Domingo.
  • Hi Domingo,
    I'm sorry, but the Nios V/c will not support debug features until some time mid next year. As a result, features that need debug, like download, are not supported until then.
    Sue
  • Hi Domingo,
    Sue
    • Benitez__Domingo's avatar
      Benitez__Domingo
      Hi Sue,
      Thank you very much for your quick reply.
      Regards. Domingo.
