Jordan14's avatar
Jordan14
8 months ago
NIOS V on-die temperature sensor for Stratix 10
Hi~How do I get the on-die temperature of an FPGA in a Stratix10 NIOS-V processor? I see examples with MAX10 and Arria10, but that IP core is not on the Stratix10, thanks
  • I would recommend that you look at the latest version of the Mailbox Client IPs User Guide located here:
    https://www.intel.com/content/www/us/en/docs/programmable/683290/25-1/mailbox-client-s-user-guide.html
    Section 1.5 describes the Avalon MM interface that can be exposed on that IP core rather than the Avalon ST interface that you are referring to. Connecting a Nios V to the Avalon MM interface would be much simpler and more straight forward.
    Section 1.11 describes the Nios V HAL software support that can be used to interact with the Mailbox Client IP core.
