NIOS V on-die temperature sensor for Stratix 10
- 1 year ago
I would recommend that you look at the latest version of the Mailbox Client IPs User Guide located here:
Section 1.5 describes the Avalon MM interface that can be exposed on that IP core rather than the Avalon ST interface that you are referring to. Connecting a Nios V to the Avalon MM interface would be much simpler and more straight forward.
Section 1.11 describes the Nios V HAL software support that can be used to interact with the Mailbox Client IP core.
Hi, review Intel® Stratix® 10 Analog to Digital Converter User Guide. It has all instructions how to interface on-chip temperature sensor.
- Jordan141 year ago
Hi, I found the temperature sensor IP, and IP interface in Platform Designer is Avalon Streaming, how should I connect it to NIOS-V. (Quartus Pro 22.4)
