Chris039
3 years agoNios V not working
I am using example design created in
https://www.intel.com/content/www/us/en/docs/programmable/726952/22-1std-1-0-0/processor-example-design.html
I changed the loop from 1000 to 10 in ma...
- 3 years ago
Yes, the application execution starts from on-chip RAM base address 0x0.
Thank you.
Kelly
Chris039
3 years agoNow I use Design 2 and manually change the base address for cpu, ram, jtag uart to the same as Design 1 and random base address for the 2 avmm pipeline bridge. It is working now. I would like to understand
1) Why the base address automatically assigned by Quartus Platform Designer did not work?
2) Does the niosv-bsp and niosv-app have dependency on the base address?
3) If #2 is true, can you teach me how to use these 2 commands? the command --help did not explain much about the RAM base address
Thanks for helping.
