Nios-V C++ Debug Problem
- 10 months ago
Hi Balerion,
Our team have contacted with Ashling, and they have provided the solution to this issue. The latest Ashling* RiscFree* IDE v25.2.1 (version dated 09 May 2025) have resolved this issue.
You may download it separately from Quartus® Prime Pro Edition Installer for software version 25.1.1 download link.
- Click on the link.
- Select your Operating System.
- Download and launch the Installer.
- Select and install these only:
- Add-ons and Standalone Software > Ashling* RiscFree* IDE for Altera
- Add-ons and Standalone Software > Quartus® Prime Pro Edition Programmer and Tools
And use it with your Quartus® Prime Pro Edition software version 24.3.
Note: Refrain from using the 25.3 installer. It is just discovered that it is packaged with an older RiscFree IDE (version dated 31st Jan 2025). Which still have this C++ debug issue.
Liang Yu
Hi Balerion,
I spoke with a colleague and there is apparently a known issue in the Ashling Debugger for C++. As a work around, could you rename the file to .c but then in your CMAKE set the file property to set the language to C++?
Hi again,
I tried what you said but it still didn't work. I will be adding the files that I am trying. Could you please tell me what to change in my CMakeLists.txt. I added the lines below.
set_source_files_properties(
main.c
PROPERTIES LANGUAGE CXX
Balerion
- LiangYuG_Altera10 months ago
Contributor
Hi Balerion,
Liang Yu
