10 years agoNIOS UART and esp 8266
Hi all, I'm trying to make an interface between an FPGA and an esp8266 with the NIOS II UART Core, here you found my transmit and receive functions
void uart_send_data(unsigned char char1)...
10 years agoWorking without the FIFO is not an issue. But this depends on your code flow and the performance you require.
IORD returns usually a 32bit data. In the case of uart or other device registers possibly only the lower 8/16 bits are significative
