10 years agoNios stops after upgrading Hardware from SRAM to DDR3 RAM
Hi I have upgraded a working design, which had a SRAM (For instruction and Data) and a SDRAM for big Data like Packets from the MAC. The Hardware works so far, but my Software doesn't real...
10 years agoHi Trukng
Sorry, I can't share my design. I don't mix SRAM und DDR3. I have replaced an old SRAM und a SDRAM. Now I only have one DDR3 RAM for my NIOS. I'm trying to setup everything correctly, but there are just too many options like: icache dcache burst/no burst and in the DDR3: burst size reordering errorcorrecting I realized, that my dcache should be at least 32kByte. Then I don't have some system crashes. But the TCP-IP is not as fast as it was with the old SRAM/SDRAM. I think it has to do with the line "alt_dcache_flush_all();". I think this process of flushing the dcache needs a lot of time. I did some testing with the EMIF and everything seemd to be green, so my hardware design is ok.
