15 years agoNIOS SOPC Migration Issues
I have found this to be true on several projects... Regenerating an SOPC system with a NIOS in Q9.1 or 10.0 that was origionally created from 9.0 or older simply will not work. I have all sorts of ...
15 years agoI'm having problems with this too. The SOPC system generates successfully and the FPGA build succeeds, but the sopcinfo file isn't correct and software can't be built. I can generate code using the legacy IDE tools based on the ptf file, but using the SBT along with sopcinfo does not work.
